TwinTurbo.NET: Nissan 300ZX forum - The only way to not bleed the system on a replacement>>
Subject The only way to not bleed the system on a replacement>>
Posted by ZUL8TR on March 09, 2010 at 12:02 PM
  This message has been viewed 110 times.
In Reply To can I avoid bleeding the clutch slave after installing cmc posted by mossyoak on March 09, 2010 at 11:26 AM
Message of the CMC is to do it without getting air into the system. I don't see how that can be done, so bleeding is required at both the CMC and the SC. A tip on the CMC is to bench bleed it to remove as much air as possible.
ZUL8TR in Orlando,FL
